Advertisement
H2O-gate reservoir breathers reduce dew point to prevent condensation and are 99.7% efficient in blocking particles 3 µm and larger. A visual/mechanical indicator shows when particles have blocked the media before pump cavitates. Reversible flow through media lets moisture exit the reservoir. Eaton Hydraulics, (800) 547-7805, www.hydraulics.eaton.com
