Filtration system
The 3K9 single pass filter kit features three K9 filters mounted in series as a single assembly for in-line single pass staged filtration or particulate and water filtration. Each filter is rated for flows to 100 gpm and pressures to 900 psi. Testpoints are available in cap or block for recording pressure readings and taking fluid samples.
Schroeder Industries, (724) 318-1100, www.schroederindustries.com
