OFRP35 spin-on filters suit charge pumps and hydrostatic transmissions. They are rated for pressures to 500 psi and flows to 35 gpm. Die-cast aluminum head and cold-rolled steel bowl are compatible with petroleum, oil, water, glycol, oil-in-water, and water-in-oil fluids. One port is available for use with electric actuators. Bypass valves prevent excessive pressure drop and accidental element collapse.
Eaton Corp., (419) 891-7860, www.hydraulics.eaton.com
