Magnetic oil filtration can extend component life
Your filter is doing exactly what it's designed to do: reach a satisfactory level of cleanliness without restricting flow rates. The Halex Coil is a device that enhances the performance of your existing oil filter. The key to its effectiveness is a powerful rare-earth neodymium magnet. The coil's magnetic field draws particles that are too small for the filter to catch, resulting in cleaner oil, which will reduce wear and extend equipment life.
The Halex Coil easily attaches to the outside of an existing oil filter. With rising energy costs, the Halex Coil is becoming a preferred alternative for manufacturers looking to extend service life.
Filters are engineered to maintain flow while lubrication is passed through small holes. Smaller holes mean finer contaminates are trapped. The coil is a filter that performs better than its micron rating without changing flow-rate and without intruding on internal systems. It's simply a different way to trap more, as it traps 40-90% of iron that would otherwise pass through the existing filter medium. By bonding and piggybacking on the existing filter, it traps 20-60% of nonferrous contaminates. This can extend equipment life and service intervals, improve element efficiency and fuel economy, and reduce downtime, emissions, soot, and wear.
For more information, call Halex Development Corp.at (603) 817-6125, e-mail blaubach@magneticfiltration.com, or visit their website, magneticfiltration.com.
A powerful neodymium magnet captures particles that are too small to otherwise be caught by a filter.
