Drum topper
FlowGuard drum topper is a small and portable filtration station that acts as an off-line filter by removing dirt and moisture. It mounts directly on top of a drum and features an incorporated pump. It features an aluminum frame, two-stage filtration, clear PVC with steel wire reinforced hoses for visual confirmation of product flow, and differential filter gauges to indicate filter condition.
Des-Case Corp., (615) 672-8800, www.des-case.com
