Edited by Mary C. Gannon
The Filtration Station flushes, filters, and monitors ISO cleanliness with user-defined, automatic features. It transfers fluid through two K9 filters in series for staged particulate or water/particulate removal. Both filters are top-loading and include element indicators in the cap. Particle monitor samples discharged fluid from the pump and displays ISO cleanliness codes for the fluid. In auto mode, the system will run until the desired cleanliness codes are achieved. When in manual mode, the system will run continuously and display ISO codes.
Schroeder Industries, (724) 318-1100, www.schroederindustries.com
