Edited By Mary C. Gannon
Magnetic oil filters capture and contain ferrous materials circulating in an oil system to extend life of hydraulic system components and oil. By reducing friction within the system, machines run cooler, quieter, and longer. Different sizes are available, including small sticks (for use with a canister filter) and rods (for use with systems for in-line filtration). Cleaning is done by unscrewing the rod from the top of the housing and wiping it with a clean rag.
Dakota Fluid Power Inc., Y2K Div., (800) 727-2420, www.y2kfluidpower.com
