Edited By Mary C. Gannon
Senior Associate Editor
DT line of high-performance hydraulic cartridge filters are available for construction equipment, hydro-static drives, transmissions, bearing lube oil systems and other heavy-duty applications. They provide 73% higher dirt-holding capacity and 47% lower initial pressure drop than traditional filters. Synteq media technology allows high initial cleanliness and system protection. They reduce maintenance cost by extending filter life which, in turn, results in longer change intervals.
Donaldson Co.
(952) 887-3699
www.donaldson.com
