Straight and coiled polyurethane and high-pressure tubing is flexible, reliable, and kink and abrasion-resistant. Polyurethane tubing fits tube 1/16 to 1 /4 in. IDs for working pressure of 47 to 176 psi. Coiled tubing is available for 1 /16 to 1 /4 in. IDs and comes with one 16-in. straight tail and one 8-in. tail. High-pressure tubing comes in copper, nylon, Teflon, and Polyethylene for use with compression fittings. It suits ID ranges of 1 /32 to 0.170 in. for working pressures ranging from 68 to 2400 psi.
Beswick Engineering Co. Inc., (603) 433-1188, www.beswick.com
