High-pressure hose
High-pressure hose
Parker ParMax 761 hose exceeds the 100R15 requirement for high pressures. It offers a longer service life, durability, and constant 8000 psi working pressure. It is compatible with Parkrimp fittings and can be crimped without removing the hose cover due to its no-skive design. It is available in 3/4 and 1 in. sizes and can be crimped with 76 series fitting line, which are available in a variety of high-pressure 8000 psi flange shapes.
Parker Hannifin Corp., Hose Products Div.,
(440) 943-5700,
www.parkerhose.com
