Wide variety of hose
PTFE-lined stainless steel braided hose is rated for 3000 psig with end connections from 1/8 to 11/2 in. and 6 to 25 mm. Stainless-steel FM and FL flexible hose is rated for pressures to 3100 and 1500 psig in 1/4 to 2 in. and 1/4 and 1/2 in. Push-on hose, with Buna N cover and core tube, is available in 1/4, 3/8, 1/2, and 3/4 in. for pressures to 350 psig. Thermoplastic hose is rated for pressures to 5000 psig and sizes from 1/4 to 1 in.
Swagelok Co.,
(440) 349-5934,
www.swagelok.com
