High-pressure hose
ParMax 761 hose has working pressure rating of 8000 psi, inner tube of oil-resistant, synthetic rubber, and six spiral piles of steel-wire reinforcement. It is oil-, weather-, and abrasion-resistant. No-skive design eliminates need for removal before crimping. It can be used with petroleum-based fluids and lubricating oils in temperatures from –40° to 125° C; water, water/oil emulsion, and water/glycol fluids to 85° C; and air to 70°C.
Parker Hannifin Corp., Hose Products Div., (440) 943-5700, www.parkerhose.com
