Following rules maximizes hose life
By T. Mueller
Most engineering efforts focus on ways to design and manufacture products that satisfy application requirements as inexpensively as possible. But you can make a satisfactory design better by making it more reliable and easier to maintain - and without spending a lot of money. How? Simply by following simple tips and recommendations offered by manufacturers. These fundamentals concern bending, alignment, motion, and similar basic guidelines.
Application basics
Unlike metal tubing, hose is flexible, so it is used primarily to allow relative motion between components at either end of the hose assembly and to simplify routing and installation. It is much easier to route a hose assembly over, under, around, or through a series of obstacles than it is to bend and install a rigid tubing assembly. Furthermore, replacing a hydraulic line by fabricating a rigid tube assembly often is more costly and time consuming than making a hose assembly.
Most manufacturers offer hose that can be bent to a tighter radius than that published in industry standards. Still, bending hose to a smaller radius than recommended should be avoided to avoid shortening service life. Therefore, route hose in a manner that provides ample bend radius.
Because hose is flexible, you must allow for contraction and expansion when cutting the hose to length. Manufacturers state that, depending on its type, hose can elongate up to 2% when pressurized, but, more importantly, can contract as much as 4%. This length differential can strain hose reinforcement wires and eventually lead to failure, especially at the hose-to-coupling interface. Therefore, cut hoses slightly longer than needed to compensate for contraction.
Bend hose in one plane only to avoid twisting its wire reinforcement, which would reduce the hose's pressure capability. Manufacturers state that twisting a high-pressure hose only 5° can reduce service life by 70%, and 7° of twist can reduce service life up to 90%. Unfortunately, hose routing usually occurs late in the design process, so it may be difficult to find an ideal path. Multi-plane bending often can be avoided by reorienting the hose. If this is not possible, install a hose clamp between bends and provide enough length on both sides of the clamp to relieve strain on the hose's reinforcement wires. This length depends on the hose ID, degree of bending, and helix angle of the particular hose's reinforcing wire, so manufacturers prefer to evaluate each application individually.
Another alternative is to use a single section of hose for each bend and install a hose-to-hose coupling and hose clamp between bends. This technique is less preferred because it not only is more costly and time consuming to perform, but increases the number of potential leak points in the hose assembly. Also, to help ensure that technicians replace and secure hose assemblies properly, include detailed instructions on hose length, use of hose clamps, and special considerations in service manuals.
Providing protection
Hose manufacturers now offer a variety of products with abrasion-resistant covers. No wonder: manufacturers state that about 80% of hose failures are attributable to external physical damage, with abrasion cited as the major culprit. Abrasion is generated primarily by hoses repeatedly rubbing against equipment surfaces or each other.
To help prevent abrasion, use clamps to secure hose in place and keep it from rubbing against adjacent surfaces. The clamp should have a snug fit around the hose to prevent movement, but not be tight enough to damage the hose by compressing it. Be sure the hose is slack on both sides of the clamp to compensate for contraction and expansion.
Additional protection can be provided by sleeves. Metal sleeves resemble springs that protect the hose from being crushed. Fabric sleeves help keep abrasive particles away from hoses, and both types can serve the added function of nestling multiple hoses into a compact bundle.
Some types of sleeves must be installed from one unconnected end of the hose and slid along its length. Others have a longitudinal slit to enable installing the sleeve without having to disconnect either end of the hose assembly.
Accommodating movement
In addition to causing twisting and abrasive wear, motion can also quickly spell doom for hoses that do not properly accommodate equipment dynamics. For example, hoses connected to a cylinder that undergoes pivoting motion must be of proper length and routed to avoid becoming kinked or bent beyond their minimum bend radius.
When multiple lengths of hose lie close to each other, and substantial linear motion will occur, hose carriers keep hoses neatly nestled to prevent tangling, twisting, and rubbing against each other. Depending on which particular type is specified, carriers can also isolate the hoses inside from potentially hostile conditions outside - impact from falling objects, abrasive particles, chemicals, or intermittent high temperatures.
Other important considerations
Most hydraulic hose is wire reinforced, which makes it an electrical conductor. For equipment that may be used near power lines or where hose will be in close proximity to flammable solutions that could be ignited by static electricity discharged from the hose, manufacturers offer non-conductive hose.
In other applications, static electricity sometimes may be discharged through the hose wall to surrounding surfaces. This is caused by conducting electrostatic charges from the fluid through the hose's metal reinforcement and cover to adjacent surfaces. Consequences can include localized burning that weakens the hose or even produces pin-size holes in the hose wall. In this case, hose with a conductive tube may be called for to conduct electrostatic charges to hose end fittings rather than through the hose.
Just as twisting can dramatically shorten hose life, so can excessive heat. Heat from external sources, such as exhaust components on mobile equipment, can quickly soften or embrittle the hose wall from the outside in. Therefore, it is important to keep hose away from external sources of heat. If this is not possible, manufacturers offer insulated protective sleeves to partially block heat transmitted to the hose.
However, heat from an internal source - the hydraulic fluid itself - also can reduce the service life of the hose. Pumping hydraulic fluid at a temperature of only about 18° F over the maximum recommended temperature for a hose can cut its expected life in half. What makes this problem even more serious is that machine operators often are unaware that fluid temperatures may exceed manufacturers recommendations - especially if the high temperatures occur only intermittently.
Finally, strive for neat appearance when routing hoses. This not only prevents tangling, twisting, and rubbing together (which can cause abrasive wear), but aids maintenance by making it easy to remove and re-install hose assemblies and trace circuit routing.
Use adapters sparingly because they add to the number of components in an assembly. This increases assembly time, cost, and the number of potential leak points. However, when properly applied, adapters can simplify hose assemblies that use angled fittings (such as 90° elbows) at each end. Hose-end fittings on these assemblies must be carefully oriented to prevent twisting the hose during installation. So using an angled hose coupling at one end of the hose and a straight coupling connected to an angled adapter fitting on the other eliminates the need to carefully align hose ends during assembly.
Todd Mueller is manager, hose and connector product application engineering, Gates Rubber Co., Denver.
What's wrong with this picture?
This pump and its hoses look like a combination that might be found on a typical power unit, but they exhibit two violations of hose-routing practices recommended by hose manufacturers. Can you spot them?
At first glance, this looks like almost every pump installed on a power unit. On closer inspection, however, the hose routing violates design recommendations published by Parker Hannifin and every other major hydraulic hose manufacturer in the U.S.
Notice the hose coming off the top of the pump and going into the filter. It is bent in two planes. Most hose-specification literature recommends that hose not be bent in more than one plane. Doing so can cause uneven distribution of tension to reinforcing wires within the hose. As pressure pulsations occur in the hydraulic system, the overloaded strands undergo excessive tensile stress. After continuous cycling, the over-stressed strands can fail due to fatigue and eventually cause the hose to rupture. Worse yet, the failure can be catastrophic in nature, providing little or no warning of the impending failure.
Another problem with the hose routing in the photo is the disarray of hose placement and positioning. It appears that little or no forethought was given to hose routing. It looks as if some of the hoses can rub against surrounding equipment and each other. Eventually, hose flexure from continued cycling will abrade away the hose cover. Once this happens, leakage can start &emdash; and increase over time.
Some designers may contend that there often is no way to avoid bending a hose in two planes because of the location of components. In such cases, a straight length of hose between the bends can act as a transition zone that allows the support wires to relax - but only if the straight section of hose is supported by a hose clamp.
A less-preferred alternative is to divide the hose into two separate assemblies by installing a fitting in the middle of the straight section and supporting the fitting with a stationary bulkhead plate. This technique is less preferred because the two hose assemblies and fitting increase cost and introduce potential points of leakage. The hose in the photograph has a straight section between the two bends, but clearly it is not supported by a clamp or bulkhead. Unless maximum pressure is much lower than the hose's pressure rating, the hose eventually will rupture. (If system pressure is much lower than the hose's rating, then someone paid too much by specifying a high-pressure hose that was unnecessary.)
An even simpler solution: install a 45° fitting on the pump port. The fitting would provide bending in one plane, so the hose would have to bend in only one plane. Obviously, fewer bends improve flow. In addition, the 45° fitting would have reduced the length of hose needed for assembly.
To avoid the routing confusion, the designer should have evaluated every hose assembly required and worked out a routing plan to make a neater assembly - before the first hose had been installed. If possible, hoses should be aligned parallel to each other, then clamped in place so they cannot rub.
Practicing good hose routing not only makes for a neat, clean system, but improves equipment reliability by preventing abrasive wear. It also makes maintenance easier because technicians will not have to work around a rat's nest of hoses or disconnect hoses to gain access to other components.
Submitted by Ron Mramor
Technical services engineer
Parker Hannifin Corp.
Fluid Connectors Group
Mentor, Ohio
