Hydraulic hose
Six-spiral Aeroquip hose suits applications with high-pressure spikes. It has a constant working pressure of 420 bar and operates in temperatures to 120° C. It meets EN856/100R15 with Class 0 cool-down leakage in accordance with SAE J1176 and surpasses SAE J1405 by withstanding more than 2 million flex impulse cycles. Aeroquip Internal Skive Crimp (ISC) fittings, with internal and external skive design, separate socket into three zones — damping, sealing, and wire trap.
Eaton Corp., Hydraulics Operations, (888) 258-0222, www.hydraulics.eaton.com
