Hydraulic hose
Hydraulic hoseTuff hose suits high-pressure hydraulic applications to 6500 psi. It can be bent twice as tight as standard SAE hose for half the bend radius. Reinforced internally with two braided layers of higher tensile steel wire, it has a durable, black, oil- and abrasionresistant synthetic outer cover and offers 10 times the abrasion resistance compared to standard hose cover. It withstands temperatures from –40°F to 250° F and is available in diameters from … to 1 in. ID.
Kurt Hydraulics, (866) 257-7995, www.kurthydraulics.com
