Line of FEP (fluorinated ethylene propylene) plastic tubing is durable, for applications requiring chemical resistance or exposure to a wide range of temperatures. Flexible design makes it suitable for self-retracting coils. It has nearly no moisture absorption so is easy to clean. Operating temperature range of 100° to 400° F makes it suitable for harsh environments. It comes in ODs from 18 to 12 in. Working pressures range from 230 to 445 psi and burst pressures range from 1151 to 2227 psi.
Freelin-Wade, (888) 373-9233, www.freelin-wade.com
