Series RT has been modified to enable reel to be mounted on its side, for mounting in cabinets and other tight spaces. A heavyduty side mount plate replaces the standard base. Stainless torsion spring and latch are mounted on the arm for ease of access and to eliminate the possibility of lath out at full extension. Guide arm is easily moved to one of four positions, using only standard tools.
Reelcraft Industries Inc., (800) 444-3134, www.reelcraft.com
