Compressed air hose has inner tube of Nitrile synthetic rubber, wire, and fiber reinforcement, and outer fiber braid cover to withstand the demanding requirements of air compressors. It is available in sizes from -4 (316-in.) to -40 (238-in.) and works with the following fluids in pressures to 500 psi: petroleum base hydraulic fluids, in -10° to 235°F; Polyol ester fluids up to 175°F; water, water/oil emulsion, and water glycol fluids up to 185°F; and air up to 158°F.
Parker Hannifin Corp., Hose Products Div., (440) 205-7799, www.parkerhose.com
