Balance Gauge Kit
Kit provides the hoses, fittings and a sturdy carrying case for quick system balancing. It is designed for use when several pressurized vessels must be pressure or flow balanced using a zero center differential pressure gauge. It is available in many ranges and scales from ±1-in. water to ±100 psid. Options include bleed vent valves and several dial sizes.
Balance gauge kit
Differential Pressure Plus Inc.
(203) 481-2545
www.differentialpressure.com
