CBP compact motors feature low weight and transmit high power of more than 1000 kW (1400 hp). Flange-mounted or mounted with torque arm, they are fitted with splines and have through-shafts. Five sizes run at high speeds for high efficiency, with displacements of 5024 to 52,800 cm3/rev. With a wide operating range, they produce torque of 80 to 840 N-m/bar, with rated speeds of 320 to 270 rpm and maximum speeds of 115 to 400 rpm. They operate to maximum pressure of 350 bar.
Hagglunds Drives, (614) 527-7412, www.hagglunds.com
