Char-Lynn T-Brake motors combine high torque and high loading capacity in a package 20% shorter and 50% lighter than others. Displacements range from 2.2 to 22.6 in. 3 Brake drive shaft runs rear of Geroler and is driven by collar connected to stub off the rear motor drive. Integrated rear-mounted brake offers a 6:1 torque advantage. It is available with multiple mounting types, shafts, and seals.
Eaton Hydraulics, (800) 547-7805, www.hydraulics.eaton.com
