Hydrostatic pumps
PVWC closed-loop, hydrostatic axial-piston pumps offer low hp for high-performance applications. They are rated for peak pressures to 5000 psi and maximum continuous speed to 3600 rpm and offer theoretical maximum displacements from 0.66 to 1.35 in. 3 /rev. Hardened cylinder surfaces running on a hardened valve plate with pistons on a hardened swashblock surface contribute to long operational life.
The Oilgear Co., (414) 327-1700, www.oilgear.com
