Axial piston pumps
Axial piston pumps
PVWH open-loop, axial piston pumps provide low horsepower for highperformance applications. They are available in 10 sizes for pressures to 5000 psi, and can be changed in the field without disconnecting the drive or system piping. Valve plate is ported rear or top and bottom, and pump offers low noise of 80 dBa or lower. It accepts speeds to 3000 rpm for theoretical maximum displacements from 0.66 to 7.94 in.3/rev.
The Oilgear Co.,
(414) 327-1700,
www.oilgear.com
