Variable volume piston pumps
PCP4-47 piston pumps are pressure-compensated with avariable-volume design. They reduce heat, noise, and power needs, and are rated for flows from 3.8 to 47 gpm at 1800 rpm. They maintain constant pressure while matching system flow demands. Multiple controls are offered, including standard pressure compensator, load sensing, remote compensation, and solenoid on/off.
Hyvair Corp., (281) 259-7768, www.hyvair.com
