Char-Lynn H, S, and T series spool valve motors come in nickel-plated models for corrosion protection in wash-down applications. They combine valving and hydrodynamic journal bearings in a common shaft design and provide high torque at low speeds and instant shaft reversal by simply changing direction of input/ output flow through the motor. Benefits include high efficiency and power-density, infinite bearing life at rated loads, and extended shaft seal life.
Eaton Corp., Hydraulics Operations
(952) 294-7922
www.hydraulics.eaton.com
