Char-Lynn H, S, and T valve motors come in nickel-plated models for corrosion protection in wash-down applications. They combine valving and hydrodynamic journal bearings in a common shaft design and provide high torque at low speeds and instant shaft reversal by simply changing direction of input and output flow through the motor. Benefits include high efficiency and power density, infinite bearing life at rated loads, and extended shaft seal life.
Eaton Corp., Hydraulics Operations, (952) 294-7922, www.hydraulics.eaton.com
