Axial-piston pump
PVG open loop pump series offers high pressure and high performance in a compact design. Available in five displacements from 2.93 to 7.94 in.3/rev and multiple frame sizes, it provides an instantaneous response to system commands through a high response four-way pilot operated control. It is rated for maximum pressure of 5800 psi and for speeds to 2700 rpm. Flow rates range from 21.1 to 57.6 gpm.
The Oilgear Co., (414) 327-1700, www.oilgear.com
