Axial-Piston Pumps
Axial-piston pumps
Series 760 variable-displacement, closed-circuit, piston-type pump and fixed motor is available with displacements of 130 cc/rev at 3200 rpm, and 160 cc/rev at 2950 rpm. Working pressure is 430 bar, with a high pressure relief setting of 465 bar for the pump. Features include a high displacement integral charge pump and same-side porting. Motor features standard integral shuttle valve design with optional bolt-on valve configurations for same side or rear ports.
Eaton Hydraulics
(952) 294-7992
www.hydraulics.eaton.com
