Hydraulic Power Units
table width="200" align="right">
Hydraulic power units
HKLW high-pressure power unit comes with a single-circuit pump or two pressure outlets. Hydraulic control systems can be created by directly mounting combinations of connection blocks and valve banks onto it. Finned housing with internal fan eliminates need for external heat exchanger. It is ideal for continuous operation with idle sequences as well as intermittent service.
HAWE Hydraulics
(704) 509-1599
www.hawehydraulics.com
