Bent-axis pumps, motors
SAE bent-axis XA pumps develop pressures to 5080 psi continuous and 5800 psi peak. The seven-piston units come in displacements from 1.1 to 3.84 in.3 SAE bent-axis MA motors, with displacements from 1.52 to 4.49 in.3, are available for open- or closed-loop circuits. They operate in pressures to 5800 psi continuous and 6525 psi peak, and produce rotational speeds from 50 to 8000 rpm. Spline or keyed shafts are available with SAE C4 bolt mounting configuration.
Hydro Leduc LP
(281) 679-9654
www.hydroleducusa.com
