Pump test system
Edited by Mary C. Gannon
Pump Test System
The C2000 is a complete instrumentation, display, logging, storage, and reporting solution tailored to the user’s needs. The system allows the test stand operator to produce a test certificate at the touch of a button while ensuring full ISO9000 traceability. It simplifies the test process, so an operator with minimal IT training can record data on a keypress and produce a report. It is fully scalable up to 64 inputs and can be setup to measure all hydraulic parameters such as flow, pressure, temperature, speed, contamination and torque.
Webster Instruments, (414) 769- 6400, www.webster-inst.com
