The 900 series geared speed reducers can be coupled with orbital, radial-piston, or axial-piston motors. They feature 4-planet design for high torque and life, a hardened ring gear, and large bearings on output shaft. They are rated for maximum speed input of 3500 rpm and offer ratios of 5.25:1 (others are available upon request). They are rated for intermittent peak torque of 36,000, 47,000, and 62,000 lb-in.(4000, 5300, and 7000 N-m).
Young Powertech Inc.
(888) 465- 3561
http://bit.ly/HP611YP
