Closed-loop electro-proportional control option is available for Series 1 hydrostatic pumps, providing an electronically monitored “fail-safe” system to prevent uncommanded vehicle motion in case of failure in the control spool or primary mechanical control linkage.
They also provide pressure-side filtration elements to enhance contamination resistance. They offer operating pressures up to 413 bar (6000 psi) and input speeds up to 4510 rpm while delivering 10,000 hr B10 bearing life.
Eaton’s Hydraulics Group
(952) 294-7992
http://bit.ly/HP1011Eaton
