Range of F12 Ferra two-piece pumps are available with displacements from 16 to 41 cc/rev and pressures to 276 bar (4000 psi up to 30 cc/rev). They feature a modular design with a wide choice of flange, shaft, and port options.
Cast iron housing and front cover eliminate rear cover and allow bearings to be integrated into the housing and the flange, resulting in a more compact design. Gear profile is optimized for reduced pulsation and high power density in relation to their small size.
Concentric
(815) 387-4423
http://bit.ly/HP1011Concentric
