CLDP (closed-loop differential pump) is a self-contained linear motion axis that provides overload protection, high power density, and virtually wear-free operation. An integrated servo pump — consisting of servo motor and internal gear pump — provides high energy efficiency. Displacement is optimally adapted to the surfaces of a differential cylinder by an intelligent control system with field bus connection, pressure protection, and a small compensation tank.
Voith Turbo H + L Hydraulic
subsidiary of Voith Turbo Inc.
(717) 767-3200
http://bit. ly/hp1111voith
