D series cast iron, open-circuit gear pump offers an integrated SAE A auxiliary flange to mount lower-pressure aluminum pumps to its rear. It is rated for pressures to 276 bar (4000 psi). SNP2 pump can be mounted to its through drive without adding another pump drive. Independent shaft seal on auxiliary flange isolates its hydraulic circuit from lower pressure auxiliary pump, to allow operating two separate hydraulic systems that require increased safety, such as steering and brakes, but also the ability to leave the auxiliary pump.
Turolla OpenCircuitGear
(515) 239-6575
http://bit.ly/hp1211turolla
