The Gemini hydraulic motor and associated drive system is constructed with the Compact CBP, which offers high speed and high output power — greater than 2700 hp. Through hole accommodates shaft or tube for fluids. Gearless, it mounts directly to shaft without gearboxes, clutches, or foundations. System efficiency equals or surpasses electromechanical drives even at higher speeds.
Hagglunds Drives
(614) 527-7400
www.hagglunds.com
