Proportional pressure reducing cartridge valve features a simple, robust, spool-type design. Regulated port is connected to tank. Features maximum inlet pressure of 210 bar and regulated pressure of 28 bar (when fitted with 29 W coil). Hysterisis is reduced without dynamic seals to prolong service life. Manual override provided for set-up and operation in case of power failure.
Integrated Hydraulics, (440) 974-3171, www.integratedhydraulics.com
