Two new valves — 1RDS702 and 1HSH701 — are compact with high pressure ratings and low pressure-drop characteristics. The 1RDS702 is used as remote sequence or pilot operated 2-port, 2-way directional valve. It offers flows of 80 lpm and pressures to 420 bar. The 1HSH701 hot oil shuttle valve provides hot oil exhaust in closed-loop, hydrostatic transmission systems, with nominal flows of 80 lpm and working pressure of 420 bar. Integrated Hydraulics Ltd., (440) 974-3171, www.integratedhydraulics.com
Advertisement
