Directional control loader valve
DV series directional control loader valve offers low leakage and high load-holding in a compact size. Featuring parallel operation, it is rated to 3000 psi for flows of 8 to 10 and 15 gpm in two spools. Metering is done with balanced, select-fit spools for minimum leakage and smooth operation. First spool is 4-way, 4-position (float) and second spool is 4-way, 3-position or regenerative.
Cross Mfg. Inc., (620) 324-5525, www.crossmfg.com
