Directional control valves
Vickers DG5V-5/7/8/10 series directional control valves feature a main-stage spool-monitoring switch. Switch comes with many sensing spool positions, including center sensing switch on A or B port end, offset sensing proximity switch on A, B, or both port ends, double offset sensing switch on A or B port ends, and center sensing switch on A port end and double offset sensing switch on B port end. Controllers create interlock safety feature.
Eaton Corp.,
(952) 937-9800,
www.eaton.com
