Series 3923 solenoid valves have stackable composite bodies to allow mixing and matching with single inlet and multiple outlets. Fully encapsulated coils, spring compensated plunger seats, and composite body provide long life. They are available in 2way, 2-position and 3-way, 2-position, direct acting, NC configurations and operate in pressures from vacuum to 200 psi, depending on orifice size and function. Coils come with DIN quick connect pin out, wire leads, or DIN connectors installed.
Spartan Scientific, (330) 758-8446, www.spartanscientific.com
