Flow-control valves
Flow-control valves include simple orifices to sophisticated closed-loop electrohydraulic valves that automatically adjust to variations in pressure and temperature.
What is in this article?:
  • Flow-control valves
fig. 1. simple fixed orifice (a) and variable orifice (b) flow controls.
Fig. 1. Simple fixed orifice (a) and variable orifice (b) flow controls.
fig. 2. flow regulator adjusts to variations in inlet and output pressures.
Fig. 2. Flow regulator adjusts to variations in inlet and output pressures.
fig. 3. bypass flow regulator returns excess flow from pump to tank.
Fig. 3. Bypass flow regulator returns excess flow from pump to tank.
fig. 4. demand-compensated flow control bypasses full pump output to tank during idle portion of work cycle.
Fig. 4. Demand-compensated flow control bypasses full pump output to tank during idle portion of work cycle.
fig. 5. pressure-compensated, variable flow-control valve adjusts to varying inlet and load pressures.
Fig. 5. Pressure-compensated, variable flow-control valve adjusts to varying inlet and load pressures.
fig. 6. pressure- and temperature-compensated, variable flow-control valve adjusts the orifice size to offset changes in fluid viscosity.
Fig. 6. Pressure- and temperature-compensated, variable flow-control valve adjusts the orifice size to offset changes in fluid viscosity.
fig. 7. priority valve supplies fluid at a set rate to a primary circuit.
Fig. 7. Priority valve supplies fluid at a set rate to a primary circuit.
fig. 8. deceleration valve slows load by being gradually closed by action of cam mounted on cylinder load.
Fig. 8. Deceleration valve slows load by being gradually closed by action of cam mounted on cylinder load.
The purpose of flow control in a hydraulic system is to regulate speed. All the devices discussed here control the speed of an actuator by regulating the flow rate. Flow rate also determines rate of energy transfer at any given pressure. The two are related in that the actuator force multiplied by the distance through which it moves (stroke) equals the work done on the load. The energy transferred must also equal the work done. Actuator speed determines the rate of energy transfer (i.e., horsepower), and speed is thus a function of flow rate.
Directional control, on the other hand, does not deal primarily with energy control, but rather with directing the energy transfer system to the proper place in the system at the proper time. Directional control valves can be thought of as fluid switches that make the desired "contacts." That is, they direct the high-energy input stream to the actuator inlet and provide a return path for the lower-energy oil.
It is of little consequence to control the energy transfer of the system through pressure and flow controls if the flow stream does not arrive at the right place at the right time. Thus, a secondary function of directional control devices might be defined as the timing of cycle events. Because fluid flow often can be throttled in directional-control valves, some measure of flow rate or pressure control can also be achieved with them.
Different types of flow measurement
Controlling flow of a fluid-power system does not necessarily mean regulating volume per unit of time from a valve. Flow rate can be specified three different ways, so it is important to be aware of how flow is to be specified or measured:
Volumetric flow rate, Qv, expressed in units of in.3/sec or min - or cc/sec or cc/min in SI metric measure - is used to calculate the linear speeds of piston rods or rotational speeds of motor shafts.
Weight flow rate, Qw, expressed in units of lb/sec or lb/min, is used to calculate power using English units of measure.
Mass flow rate, Qg, expressed in units of slugs/sec or slugs/min for English measure - or kg/sec or kg/min in SI metric measure - is used to calculate inertia forces during periods of acceleration and deceleration.
Because they control the quantity of fluid that flows through the valve per unit of time, the same control valves are used for all three types of flow rates.
Control of flow rate with valves
There are eight types of flow-control valves:
Orifices - A simple orifice in the line, Figure 1(a), is the most elementary method for controlling flow. (Note that this is also a basic pressure control device.) When used to control flow, the orifice is placed in series with the pump. An orifice can be a drilled hole in a fitting, in which case it is fixed; or it may be a calibrated needle valve, in which case it functions as a variable orifice, Figure 1(b). Both types are non-compensated flow-control devices.
Flow regulators - This device, Figure 2, which is slightly more sophisticated than a fixed orifice, consists of an orifice that senses flow rate as a pressure drop across the orifice; a compensating piston adjusts to variations in inlet and outlet pressures. This compensating ability provides closer control of flow rate under varying pressure conditions. Control accuracy may be 5%, possibly less with specially calibrated valves that operate around a given flow-rate point.
Bypass flow regulators - In this flow regulator, flow in excess of set flow rate returns to reservoir through a bypass port, Figure 3. Flow rate is controlled by throttling fluid across a variable orifice regulated by the compensator piston. The bypass flow regulator is more efficient than a standard flow regulator.
Demand-compensated flow controls - Flow controls can also bypass excess system flow to a secondary circuit, Figure 4. Fluid is routed at a controlled flow rate to the primary circuit, and bypass fluid can be used for work functions in secondary circuits without affecting the primary one. There must be flow to the primary circuit for this type of valve to function - if the primary circuit is blocked, the valve will cut off flow to the secondary circuit.
 ยป
