Emergency stop air valves
MV-EMS valves are designed for use in pneumatic emergency stop applications and fit a standard 30-mm panel mounting hole. A 40- mm red mushroom head push button has a maintained and pull-to-release feature. They feature standard -in. NPT ports, with optional …-in. brass push to connect fittings.
Mead Fluid Dynamics Inc., (773) 685-6800, www.mead-usa.com
