Valve driver
The 24P valve driver provides a simple PWM open-loop voltage controlled, 2.5 A output in direct response to front panel knob. It operates on 10-32 Vdc power with four trim pots to adjust PWM frequency, minimum and maximum output, and 0-5 sec ramp. It is fused at 5 A with an indicator and suits applications where the variable PWM output can provide a direct drive for hydraulic flow control. Options include remote panel pot, PLC control 1-6 V or 4-20 mA.
Ditco Inc., (253) 854-1002, www.ditco.net
