E.C.P. (Enhanced Corrosion Protection) provides improved rust resistance on valves for greater than 120 hr in salt spray atmosphere. It features zinc coating with black passivation for valve components in steel and cast iron; black opaque anodizing for aluminum caps and electronic boxes; zinc coating with gray or black passivation for coils and external metallic parts; and black plastic encapsulation for coils and coil’s nut rings.
Atos S.p.A.
+39 0331 922078
www.atos.com
