Proportional flow control cartridge valves work with hydraulic integrated circuits to regulate fluid flow that controls specific equipment operation. Three cavity sizes — 10, 12, and 16 — come in eight schemes, including NO and NC for priority pressure compensated, restrictive pressure compensated, restrictive spool (non-compensated), and restrictive poppet (noncompensated) valves. They are rated to pressures of 3770 psi and maximum flow rates to 32 gpm.
Sauer-Danfoss Inc.
(515) 239-6593
www.sauer-danfoss.com
