Edited by Mary C. Gannon
VE10, VE30 and VE60 exchange valves are suitable for exchange flows from 10 to 60 lpm in circuits at 450 bar. Exchange pressure can be adjusted between 12 and 30 bar using VE30 and VE60 versions. They enable some of the hot oil to be diverted and transported to a cooler. The cooled oil is then able to continuously regulate the temperature of the hydraulic circuit. Compact size allows for easy integration into all types of hydraulic circuits.
Poclain Hydraulics Inc.
(262) 321-0688
www.poclain-hydraulics.com
