Heavy-duty flow-control valves
Heavy-duty priority flow-control valves provide a simple and efficient way to supply auxiliary hydraulic power to mobile work tools and attachments. Valves can be added to existing systems without modifying a machine’s directional-control valve. Also called hammer valves, they are available for single pump, double pump, or load sensing. They feature zinc-plated steel bodies, IP69-rated coils, and three-way configuration: one pump inlet port and two outlet ports for priority and bypass flow.
Bosch Rexroth,
(610) 694-8298, www.boschrexroth-us.com/brh-m
