Directional solenoid valves
D03 zero-leak solenoid actuated directional valves provide reliable actuation of single- or double-acting cylinders. Poppet-style 3- and 4-way valves are rated to 5000 psi (340 bar) for intermittent pressure and flow. They mount to an international standard valve subplate; 1.93-in. width allows for mounting multiple valves on 2.0-in. centers. With nominal flow rate of 3.0 gpm (11.4 lpm), they are compatible with most industrial grade hydraulic fluids and operate at temperatures from –65° to 225° F (-54°to 104° C).
Interface Devices Inc.
(203) 878-4648
http://bit.ly/HP611InterfaceDev
